This DIY will help you align the gear shift cable linkage in its left gate together with the gearbox.
Dealer should do this under warranty if you have problems with crunchy 1st/2nd gear, do this on your own risk. But for me it was less hassle/wait DIY than going to the dealer.
Also if you have a bad case, probably better to go through dealer. Mine was almost on point with only the very odd clunky/crunchy change.
If you only have issues under quick changes, slow them down or get an torque mount insert.
Tools: set of screwdrivers 2x flat - and one +, and some masking tape. 10mm socket + extension
Step one: remove centre console according to this vid:
If you have a shift riser installed (like me), only need to remove top trim around shifter (as shown)
Step two: watch this vid first how to remove the intake but read on for a shortcut:
Shortcut: only remove snorkel and intake hose. Then, carefully take off the airbox lid and put to the side (use tape). Lift out vacuum hose running on the left/front on the airbox from its clips, then carefully lift off and put the airbox to the right and fix with tape for access to the gear linkage.
Step 3: open up the linkage joint to the left (green arrow first pic) of the shifter base according to this vid (shifter must be in NEUTRAL):
Step 4: lock the gear linkage at the gearbox (corresponding to left gate) as follows:
1) press down the linkage/black weight one notch (approx 8mm) and hold it there. (if you press down further it's reverse)
2) press and hold down button
3) push in handle rear-right direction (pushing in a pin and locking the linkage position)
Let go of button 2) and the linkage should stay put in its depressed position (some minor play there). Look like this
Step 5: Back in the car, move shift lever to the left (gate), the reverse lockout (black) resting against the white cam/ridge to the left (do NOT select 1st, 2nd or reverse). Holding the shift lever there, push back the orange clip in the shift linkage joint at the base of the shift assembly (the one we opened in step 3). Now we have reset the linkage to factory settings.
Step 6: free up the linkage at the gearbox by pulling left/forward the handle in step 4 nr 3. (DO NOT push button 2, you might inadvertently pull out the whole handle/pin). Now the linkage should jump back to neutral, just like the gearshift.
Step 7: test the gearshifts, if all feels good, reassemble the centre console and the airbox in reverse order. If not, redo from step 3 and find what you did wrong.
Done!
Done!
