GR86 GR86 Brake upgrade Poll
Are you planning on any brake upgrades
  • 1. No - should be happy with OEM
    Votes: 26 40.6%
  • 2. Yes - OEM calipers , Aftermarket pads / discs
    Votes: 15 23.4%
  • 3 . Yes - Aftermarket Front Brake kit
    Votes: 5 7.8%
  • 4. Yes - Aftermarket Front and rear Brake kit
    Votes: 10 15.6%
  • 5. Undecided
    Votes: 8 12.5%
  • Total voters
    64
Where did you get the paint? I was thinking red against EB would look good, then I had a look on ECP and they have 2 very similar blues that might be a match for EB (https://www.eurocarparts.com/caliper-paint) but if they don't quite match then it will look a bit jarring like someone has not matched the paint correctly, so it might look better with a contrast rather than a paint that is a couple of shades out.๐Ÿค”
I used caliper paint from Amazon - One tin for under a tenner did 4 coats on each caliper with plenty left over.
1 x 150ml Bright Red Heat Resistant Gloss Brake Calliper and Engine Block Paint. Caliper Engine Bay https://amzn.eu/d/fXR7Yjg
These also perfectly fit the factory jack points on the frame rail for the jack stands
DEDC 1PCS Square Jack Stand Pad for Toe Jack Axle Stands, Rubber Slotted Frame Rail Protector, Pinch Welds Protector 2.36x2.75x1.38inch https://amzn.eu/d/gfsHycB
They look way better๐Ÿ‘ Did you paint them in situ or remove them ๐Ÿค”
It situ, just my preference. Taped them up but once the first coat went on it was easy. As you say, it's a huge improvement.
