GR Yaris GR YARIS - UNDERSEALING - LANOGUARD
Flytt34
Hi All,
I first read about this product (Lanoguard) on this forum funnily enough. I decided to obtain some and was going to undertake the job myself but lost interest and then struggled to find someone to do it. That was until I went here https://ccr-restoration.com/ - Kent Classic Car Restoration based in Mereworth, Kent.
Although they were unfamiliar with the product and used to using more established ones, the upshot is that they loved it, easy to use, easy to clean off, and restores the underneath with a nice shine looking like new. They recommended a short top up yearly.
The inner wings were removed, and all the inner seals sprayed all with one bottle plus grease. So, it also goes a long way. The job was completed in a day. Plus, they loved the car!!
A top job and a top product. Thanks to Phil at KCCR and Mark (I believe) at Lanoguard.
I received no payment or sponsorship for this review, I was very surprised.
Flytt34
Reactions: MrJ
Im doing this myself in the next few weeks....ive swotted up about it and believe it is good stuff.
My only concern is how long it stays sticky for...lanoguard said 8-10 days till fully cured.
I use it, and think it’s great stuff. It’s not nasty and toxic, so you really don’t have to be too careful when spraying, other than brake discs of course.
There’s only really one downside for me, and that’s the appearance. I’ve always had to drive the car pretty much as soon as it’s applied, and it does attract dirt while still sticky. I don’t look at the underneath of my car, and so don’t really care too much, but might be a dealbreaker for some.
I topped it up again last week, warming some up and putting it in a trigger sprayer. Everything is still looking good under there, although I have to admit, I didn’t remove the wheel arch liners and floor covers. I will do that at some point, but maybe when I have my own driveway.
I’m on 12k miles now and have just had this video back from the service if you’re interested in seeing how it’s looking under there now:
It’s been washed since 😆
It doesn’t cure - I put it on my car on day 1 and I removed it this summer as the crap that stuck to it was annoying me
The car was brand new still once removed so it does work but everything sticks to it
That’s mine with 3500 miles on after I removed the lanoguard
It does work but it messy
To removed it I tried TFR, citrus cleaner and water based degreaser and nothing touched it
I got some gunk and that did the trick
When I just fitted my winter wheels i applied acf50 as it’s less messy and does work. It won’t be as good as the lanoguard but I don’t do many miles and wash under the car regularly
Hi,
The underside looks great. As mentioned, the 8-10 days curing might be a problem for some.
Flytt34
View attachment 8837View attachment 8838View attachment 8839
Yep, this. As my only car, running through winter, with only the local jet wash to clean it, it’s ideal and looks far better than not using it. If you have more time to take care of it and keep the underneath looking clean and OEM then it might not be for you. I should add that I totally over apply the stuff and spray it everywhere.
