GR Yaris GR Yaris front axle nut tightening torque
kaarel194
Hi!
I can´t seem to find anywhere the tightening torque for the front axle nut. Does anyone know the torque spec?
Genuine wheels 103 Nm, after market wheels mostly 120 Nm
Bye for now Fred
Ups! Was too fast in answering, sorry. Bloody foreigners... ;)
Hi!
10. INSTALL FRONT AXLE SHAFT NUT
(a) Clean the threaded parts on the front drive shaft assembly and a new front axle shaft nut using non-residue solvent.
NOTICE:
  • Be sure to perform this work even when using a new front drive shaft assembly.
  • Keep the threaded parts free of oil and foreign matter.
(b) Using a 30 mm deep socket wrench, install the front axle shaft nut while applying the brakes.
Torque:
294 N·m {2998 kgf·cm, 217 ft·lbf}
(c) Using a chisel and a hammer, stake the front axle shaft nut.
assuming correct socket is "double hex" as referred in Phil's video.
Worth also noting that axle shaft nut needs to be replaced after opened, got them today from Toyota parts and they were 8.6€ each so not that expensive.
