- Dec 27, 2021
- 1,747
- 2,892
I've had this for a while and and I figured it's about time I tried to figure out what might be causing it!
At much above 140 km/h (87 mph, fact fans) I hear what sounds like something fluttering right behind the instrument binnacle. It's exactly the kind of noise you'd hear if a bag or something was trapped under the car, but of of course I've checked, even removed the undertray, and cannot find anything obvious stuck anywhere.
The car has also had at least two services where, although I haven't mentioned it, none of the techs has ever identified anything untoward either.
It's clearly speed-related, being inaudible under about 120 km/h and get's more strident as you get faster until it gets drowned out by other wind and road noise when you get above 200 km/h.
I'm sure the 'right behind the instruments' is just an audio quirk and the actual source is somewhere else, just audible through the bulkhead at the most obvious point.
Apart from the noise the car runs just perfectly; no ill effects after over a year, and it definitely started at one point about a year or so ago.
Anything anyone can think to check? I can only assume something is loose or there is a crisp packet lodged somewhere that I cannot see!
