GR Yaris Wheels from other car models
brynasalex
Fascinated Member
Gothenburg Swden
Hi,
My plan now is to source a set of winter wheels for my newly arrived GR. To minimize cost, the plan is to buy used, but the GR is not that common in Sweden so hard to find.
To widen my search I am thinking about wheels from other cars( both OEM and after market). To help with the search, I am interested in what other models have wheels that fit, if some model have.
Would be happy if someone has this knowledge.
/Alexander
Just find what other cars have a 114.3 x 5 pcd. Depending on suspension P 45 to 35 and 18" or 19" and a few 17". Hubcentic adapters can get you the correct centrebore as long as the wheel is bigger than the hub.
Plenty of info here in various aftermarket wheel threads.
Just about any aluminium wheels of the correct size from Toyota or Lexus will have the correct bore and stud spacing, the offset varies though.
I have 7.5 x 18 Avensis wheels on my Winters, the only problem is that the outside face of the front calipers is VERY close to the inside face of the wheel spokes.
Sorted with 2mm steel spacers.
I got some Lexus GS300 wheels for my winters. No problems.
Thank you all very much for the specific models that fit the GR. It will certainly help with searching for wheels.
Hi,
/Alexander
Mine are from an evo x mr
Hope this helps
Cheers from Perth Western Australia 👍
