GR Yaris Post your Best Updates for the GR so far!
What size are you both? Just asking because I am pretty standard size and was hoping the steering wheel would fit therefore.
Oh and in normal sense units please. I don't have five or six feet on my own to measure myself for comparison and don't want to ask the neighbours every time.
Yeah, you need to stop asking the neighbours 🤣
I'm approximately 180cm.
Or is it cc? No, that's a different thing.
I'm 1m83 but it's more about build. I usually never have the wheel close enough on any car and it was even worse on the GRY. So getting the spacer was very basic in getting a good feeling with the car...
I see. Thanks for the info. So both slightly more on the taller side. I am about 175 cm. Found that most Japanese cars are build withe 170 to 175 people in mind. Volkswagen chief developer told me German cars are sized for just above 180. Guess I shouldn't be in need of a spacer than. Hopefully I can confirm my prediction some day.
Aus made Velo seat and AGI mount.
Transformed the car.
I will look closely at the stock seat to see if it can be modified to allow it to sit lower though.
I supposed I do not.
There are no other modifications to the car at all.
IMHO, this ADR approved seat makes the car safer as visibility under the mirror has increased I'm less likely to lose control in an avoidance situation as the driving position has improved. These issues are known to Toyota as they changed them in the GR Yaris 2.
Having the seat airbag removed only affects me as the driver in the unlikely event of an accident and no one else on the road or in the car.
Police have seen it and have not said anything. Plus I firmly believe in having the dignity of risk, such as driving old cars without any airbags at all and still expecting to get repaired at a hospital emergency department if need be.
Post your best updates to this thread!
Mine have been so far (90105-17013) Camber bolts and wheel alignment 120€ in total.
Spiced up the cars handling - now the steering feel is much better (was bit numb initially) and front axle gained quite a bit more traction in corners. Front has now -2.2 camber and 0.14 degree total toe out.
Funny it took over 6months to get this done. Kind of made the car reborn again as it gained another level in terms of performance and handling.
Totally agree and I used the ‘Lauren’ settings from the site from new . Is Lauren still around , as she was a wise poster and obviously a very competent steerer . ??
Setting Tyre pressures to 32 psi front and 34 psi rear enlivens the handling along with the camber bolts .
A notch in the mirror ‘bulb’ as per the old site raised the mirror enough for me and been happy since . Very cheap !!
Cut front splash guards from a 5$ plastic bucket and have saved the car flanks in 50 k and off road ( dirt) trips . Tucked in under wheel arch liners .
Decent set of horns but had to take the front off . Easy . New car has 3 piece bumper which would make life easier . Also fitted Light bar behind grill and bug mesh for my big trip. Left the bug mesh on as acts as stone guard .
Page 3 and no one has mentioned the lower torque arm bush. Yours WILL be split and sloppy. The gear change quality improves 100% for £35 and a bit of scrabbling about under the car. More than one supplier out there, I happened to fit this one.
Whiteline Torque bush
This helped me for about 500 miles - the gear change went back to being 'tight' like it was from new but now it's feeling 'sloppy' again so I may need to invest in a full aftermarket torque mount! :confused:
Might try the Airtec one unless Hardrace bring one out!? :unsure:
:) (y)
Do you have any more photos showing it as a single bucket seat next to the OE seat?
Been tempted to put an ex Freddy Loix bucket in mine, although never liked the look of odd seats
:) (y)
I feel the same. I did all three mounts at once and it made a difference but there’s still room for improvement with the gearshift feel.
