GR Yaris (Gen 2) Onehp's first thoughts on the mk2 2024 features
Onehp
Svveden
Two days in since it landed, assuming here all read the articles/specs and saw the vids from here forward: https://www.gr-zoo.com/threads/gr-yaris-mk2-my2024.3989/page-22#
Some first thoughts of mine on the mk2 (2024) updates, how I think it could compare to the mk1 (2020) a bit more in depth with my very subjective and very preliminary evaluation. And also my personal reflection as an road driving enthusiast with a oem+ modified mk1 which I adore as a driving tool, and how I see the 2024 car in comparison relative to my enjoyment of the car.
This is basically a mental exercise for myself that I share in case it helps others. My initial reaction is that, as it turns out, I have naturally developed my car during my 2,5 yr ownership and actually nice to see Toyota did the same from the beginning of the mk1 without anyone taking much notice. And it follows what many people have done. In other parts it surprises a bit. Still very nice that a manufacturer listens and keeps the concept alive, true to the enthusiast marketing for once. Anyhow let's dive in!
1 Spring rates
Higher spring rates and stiffer front arb signal to me some more focus on track driving (now rates are more or less on par with i.e. KW v4 clubsports) , which remains the mainstream way to judge a ’performance’ car and how many chose to enjoy this car – something that perhaps surprised Toyota that it was so popular as a track car.. No word on damper changes but they probably follow suit. I do wonder how bumpy b-road behavior will be, might be that the mk1 remains an as good or perhaps even better proposition there. Remains to be seen. All I can say I’m happy how the mk1 deals with real roads…
2 Roll stiffness
Front springrate has increased more then rear, and also front arb stiffened. This means roll stiffness in front is increased, meaning on cornering limit and on trailbraking, the rear should keep it wheels more on the ground then before (and front less). This could mean improved rear push out of high G corners which could counteract some increased understeer on neutral balance. Also when going really wild, donuts, in high grip, the mk1 can lift a rear inner wheel which takes away the Torsen working and losing all rear drive, this should counteract this. This is what I think they refer to as ’the car not doing as you want’ and how they solved that. Modified cars with equally higher spring rates front and rear in effect do the same, as the wheel rate at the rear is almost half the spring rate, meaning that an even increase in rates actually increases front roll stiffness more than the rear in absolute terms. Not a biggie for road driving, only noticeable when really pushing on and over the limit on high grip surfaces.
3 Stiffer front McPherson top mount and reinforced lower suspension arm
Less dynamic camber change, maybe some small increase in static camber too? Less understeer. Definitely sound like a good improvement especially for high load situations. Should also improve steering feel. Great. Maybe I want those arms on my mk1 if a straight swap.
4 Stiffer body with more spot welds and adhesive
GRMN vibes here, kudos for implementating it also for the ’base’ car. At the same time also necessary when increasing spring rates without worsening the handling. Mk2 should feel even more solid because of this but again the mk1 wasn’t really lacking either unless again pushing very hard.
5 Engine
In short, GR Corolla upgrades with better breathing head/exhaust valves and more robust valvetrain (springs). Better ECU programming incl injection is welcome. Remains to be seen in practice how big difference it is. For tuning it will allow for a bigger power bump without running into valvetrain issues, which is not the same as saying that tuning is univocally recommended but definitely a plus for those pushing for power on a stock engine. Stock for stock, a nice improvement but not a day and night one. For me, my car sits roughly where the mk2 sits now with hardware changes and without much change in boost, feels like the correct long term approach, on a mk2 I would probably still want to do similar upgrades I have resulting in a slightly bigger delta as I'd dear a bit more, maybe 40hp delta? But power is a bit overrated for actual driver enjoyment...
6 Gearbox
Well documented, the DAT reminds me a bit of a reliable, liveable, cheap, low maintenance but not as sharp or edgy sequential box. Love how close the lever is and the correct shift direction – may seem minor but for me a big deal and almost akin having an electronic parking brake or a manual one, day and night. Almost. For track driving should definitely try the DAT, will also get rid of lag on upshifts.
For road I personally still prefer manual for the involvement and the total unnecessary but of so fun three pedal dance. Manual gearbox not much changes it seems, but at least some small improvements and we also know under the skin improvements have already been made on the mk1. Pedals unchanged so still need to extend or move gas pedal for proper heel-toe...
7 Cooling
Additional radiator for coolant. I suspect there is a beefier water to oil cooler in there (like the GRC) so the oil temps benefit from the increase cooling capacity of the coolant. Also added complexity, coolant hoses run low and potentially right front damage could become more costly.
For me, my main issue remains not getting oil hot enough, so don’t need more cooling for road use. Which isn’t the same as heat soak, which I do a actively try to counteract in my mods. Mk2 will offer if correct understood IC water spray and a cold(er) air intake, kudos for that (at a cost but oem so you get some more back too come sale). Wonder if they ditched the intake box flap or if it still suffers of high IAT.
8 GPS based track mode with anti-lag etc
Would love the anti-lag on the road, have basically improved my car driving skills by using LFB as an out of bend anti-lag… The max fan speed after track session to remove heat soak is a feature I’m already looking for a solution to implement on the mk1 https://www.gr-zoo.com/threads/how-to-activate-radiator-fan-earlier-to-combat-heat-soak.5177/ (anyone has ideas how to?). Great minds think alike ;)
9 New front aft power distribution
On the mk1 I always used track 50/50 as it imho was the most consistent for near or over limit driving, whether snow, gravel or asphalt. Sometimes I also used 60:40 normal on gravel. So the new gravel mode with slight front bias really makes sense to me. Mk1 sport mode was a bit less consistent with over and also understeer on limit (but fun on the road), the new mk2 track setting make sense to me as the variable distribution allows for the best distribution to make progress. If the rear is pushing understeer it could send more to front to activate the front diff, if oversteer it could again send more to front to straighten out, for off the line and out of curve traction it can send more to the rear. Or that is how I image it. Remains to be seen the actual calibration. We’ll see what the new consensus becomes, if the new variable track is the go to or if some will still prefer the ’old track now called gravel’ for track use. I’ve been perfectly happy on the mk1 with the 50:50 track, one go-to setting what’s not to like…
10 Driving modes
Usually not a fan as I like that one setting that does it for me, consistently, however have to love the possibility to set-up the car to ones preffered custom setting, it’s like built-in set-up tuning that can potentially save on what otherwise would be cost mods.
11 Ergonomic improvements
Always welcome, the 25mm lower seats give the choice without risking crash integrity. Steering relocated it says but not sure if reach was improved. Pedal box unchanged. Some are already very happy with lowering the seat on the mk1, and then the mk2 factory mod is perfect. For me I’ve learned on my previous car (VAG ea888g3), after complaining for years the seat was too high, that I sat even better rsising the seat resulting in better steering and pedal ergonomics – for a car than wasn’t from the outset designed to be a low seat ergonomics car like e.g. the GT/GR86. So for long-legged me, mk1 seat height is spot on and the mk2 probably brings no benefit whatsoever and I would probably still want a steering wheel spacer… for me. YMMV
12 JDM only RC optional forward handbrake
Great idea but imho looks awful. Very happy with my half bought/half DIY handbrake extension that sits just beside my extended wheel. Again similar thought train.
13 Aero improvements
The open mesh where the diffuser is makes sense, more so then the rear arch vents… hoping for a mk1 aftermarket version…
14 Visibility
Higher rear view mirror good, but from what I see it still can’t be all the way up as you lose line of sight through the low rear window (or is the sight line really higher without thw 3rd brake light?), and do love my digital rear view mirror as it’s still an massive upgrade on all accounts. Infotainment screen line of sight for me a non issue, maybe it is when lowering the seat and short drivers think it’s a wtcc car…
15 New interior
I can reach all controls on the mk1 but appreciate the race philosophy and the benefit for some. People saying they think it’s ugly and they have to look at it all the time, go buy an Audi - I look out of the windows most of the time ;) No just kidding it's ok to not like the new dash - as long as you can see past it. Otherwise buy an Audi. Sorry again for that ;) Anyway, more info with digital dash, again racecar, so what not to like but I do like my anolog dials... Potaeto/Potaato
16 Front bumper in sections and metal grille
Very good for cheaper repairs. What’s not to like
17 Looks
Subjective but I personally think it got a bit more track car look and less rally. Which alignes more or less with how I see these cars. Love the grey which blends well with the new front, wish it came on the mk1. My unwashed black one is effectively grey though :D
18 Final thoughts and considerations
New car is I suspect little more track use biased and definitely a better choice for those considering such high load use. For more rally/gravel and road use, the mk1 one might still be as or near as good depending on your use case – not really using much of the improvements, and at a slightly more accesible price point as can be reasonably assumed. For my use I don’t see a significant change in driver enjoyment if I changed, and I would need to carry over mods which is a hassle on top of the price hit (size tbc).
But if I were by buying new, I would go for the mk2 almost for sure, well again depending on price. The Mk2 has good improvements but in the big picture, they are incremental and the driver remains the centre on both and also the biggest variable…
I see some parallels to the Mitsu Evo lineup, later models are more or less equally sought after as earlier ones, choosing between more complex or more basic, all appreciated and with many upgrades that can be shared. There will probably be a price gap near future that remains fairly steady as the mk1 will remain attractive at a lower price and taps in first in affordability for those who fancy one. Also think the mk1 with choice mods towards the mk2 might gain in acceptance. Could also be the mk2 understeers even more and people think the mk1 is a sweeter drive. Or maybe mk2 damping is much better and it's just better overall. Time will tell.
I’ll be honest, part of me was wishing there was no mk2 but now it is here, I really like it is here and will keep the GR Yaris at large more actual. And while reduced exclusivity and a new model seemingly sucks for residuals, for me I was previously worried that if someone totals my mk1, it would not feel good to get a used one and have to start from almost scratch with mods, I would feel robbed. But now , I could start from something that has come some way forward – a grey one please in such case, wanted that colour from the start, and maybe take it in a slightly different direction as I grow with it.
Still feel very fortunate of having been able to enjoy the mk1 for three years+ before the mk2 shows up on the streets.
Welcome to share your opinion on the above, adding from your experience...
I liked reading this, especially the comparison to the Mitsu Evo lineup. Totally relatable.
Take the NA1 NSX, for example. It got a facelift in the NA2, which was objectively better, but there are still loads of fans who prefer the NA1 for its looks or the more raw feel. The NA2 was pretty much the same car, just with a few tweaks here and there. It had a slightly bigger engine and, like the MK1 GR Yaris, came with only a manual transmission, while the NA2 added an automatic option, just like the MK2 GR Yaris.
We could even talk about the S2000's evolution. Although quite similar on the outside, the facelifted AP2 in North America and Japan brought major changes to the drivetrain and suspension. Unsurprisingly though, the AP1 is often favored over the AP2. Mainly because the AP1 revved higher and had a throttle cable, which doesn't really relate to the MK2 GR Yaris, but you get the point.
Very good points. Both later ones improved respectively fixed the handling, and NA2 got stiffer body and a significant bump in power - similarities are there.
People still appreciate the originals....
Very extensive and thorough thoughts @Onehp , thanks for it!
It is very interesting to have test drive and how the car feels. My gut feeling is that given the car is driven so much on track, they had to mitigate some of the biggest issues the car had on faster track driving, namely heat and soft suspension.
As you said, it is to be seen what spring rates are sweetspot for the road. I generally like the weight transfer of GR on the road as it brings playfullness to the cassis. Too stiff would destroy it but assuming it is only minor change maybe it is not that evindent. remember that they had to manage the extra 20kg from auto so it maybe explains the higher front spring rate too.
Heat management is to be seen aswell, as I felt water temps was not really the issue but oil. maybe it works with 2x larger oil to water heat exhanger, but I'm bit sceptic with this.
I feel heat plays some role in engine mechanical failures here so they had to do it to avoid more problems with cars driven a lot on the track.
My approach with cooling would have been slightly different. Transfer case heat issue - was it mitigated? extra oil cooler would be been nice, a beefy one from the factory (maybe with selectable option). Also centre diff heat is likely still the same. Oil pan still the same?
Generally with all the imporovements mk2 is tempting and obvious choice for 1st buyer. Power in these cars is difficult topic - somewhere there is sweetspot and unless driving against clock nicely delivered 300hp can be better than aggressive 400hp. It is of course what kind of car you're after, playing with chassis and power on nice roads no matter the speed, or getting adrenaline kicks from fast acceleration - both have their sides.
The way they sold the car could have been different. OEM performance upgrades to mitigate the areas how you use the car, meaning selectable cooling pack, spring rates, undertray protection etc. Of course you can do the same with aftermarket parts but it would have been so much more fun if the final touches would have been done from the factory.
With GRMN they had this, maybe too difficult and brings too many variables for generic GR Yaris. but I liked that approach.
1 Spring rates
2 Roll stiffness
5 Engine
6 Gearbox
7 Cooling
10 Driving modes
14 Visibility
15 New interior
17 Looks
Thanks for writing and sharing, detailed and thorough!!
You're Great at it :)
Eventually I will of course drive and compare the two, but I am a strong believer of the OG still (MK1) and it suits my needs and desire that actually was completed when I bought the GR Yaris, the WRC Homologation machine that I've been wanting since I started to go to WRC competitions late 80's 😁
This is after owning plenty of potential cars for the road and track, but never with the Rally-approach that comes with ice-snow-gravel specifics this car handles so well. Apart from asphalt of course.
Being able to visit TGR WRT HQ and get the background explained and seen with my own eyes, seeing the WRC cars in building/maintained and prepared just have me in it's grip making this more magic for myself. And I'm enjoying that, in my head and heart :love:
I am definitely not against development and evolution and the MK2 will do great for the next level of Gazoo Racing breeds for Toyota and the new segment it will attract. The improvements you listed are good ones for all drivers, perhaps an overweight towards track driving as Rally use on a competing level is something different from a track machine, where you really do re-build most of the car either way. But for road use the updates are nice most likely.
After all it is a positive sign that Toyota is continuing the development of these type of cars, 2024!
For now I guess am treating the MK2 as another car, but not saying I can't or won't change my mind later on 🏁
Thanks again for the writing!
Yes, hmm, difficult.
I actually find it quite easy in my position.
I have the MK1 with Eventuri, so the intake thing is done. Wagner LLK and larger pipes etc. Kelford springs in the engine. Complete chassis subsequently stiffened and braced. Almost 390 hp. Spring rates, dont care its not oem.
If I ever liked the front from the MK2 better, it could be swapped.
What else have I forgotten that brings me “added value”? Nothing? More electronic features? Everyone knows I hate this... 124 different driving modes? I don't need it, I don't want it.
The interior....ok, I don't really care. I find the old one ugly and the new one even uglier. But that has never interested me.
I have really perfected my GRY in my own eyes and "for me" (with a lot of money :) ). The way the MK2 stands now, I would get worse or start from 0 again.
Things like anti lag features, in Germany :)))). sry, I have a little urine in my pants from laughing. (Psssst but i can activate it on my MK1 with OEM Ecu 😛)
As a MK1 owner, stay cool. Enjoy your MK1.
This common marketing talk of “the new one, the better one, the only one!” Unimportant.
Personally, it's not enough what the new one brings. Same seats, same steering wheel, body, everything the same.....
if a powerful hybrid had come along, I would have gone crazy and pressed the order button until it exploded :).
In addition, no one knows what else is coming in mid-2024 and the EU with new vehicles... what controls and driving aids etc. will come in? Can't I turn something off? What procedure do I have to go through to do it? I would still wait and see.
Finally. Enjoy your vehicles, whether MK1 or MK2 or ultimately something completely different. Doesn't matter:).
I've not really paid much attention but I hear people complaining that it was all marketing BS that Toyota lost money on the Mk1. I don't believe it and they could as well be losing money on the Mk2 - they do sell millions of cars and the project is more of a testament to Morizo's passion for motorsports that they're keeping the thing going. Would I have liked to have seen production limited and this platform never repeated? I think it's selfish to think like that. The longer major car companies resist the regulations and have the will to produce wonderful little ICE cars, purely for fun, it's something to be applauded.
In the very near future, with the rules around EV quotas, it's highly unlikely we'll see a Mk3 or a Mk4 - unless the powertrain is radically altered and then, for me, it becomes heavier and a very different experience altogether.
My take on the mk2, I’ve seen it in the flesh and have discussed with people (who actually had been driving one) what it feels like. In detail:
The mk2 is no question a better car, a better machine for its intended use. In tarmac, gravel and snow.
The increase in power is listed a 20 hp more, but it feels more noticeable than that. You can play with powerslides now when with the mk1 on stock form, on dry tarmac, it wasn’t achievable without using weight transfer. Maybe some tweaks with traction modes, help on that.
Traction modes.
In the mk1, they were already variable, so not a massive change here, just different marketing. For me, mk1 track mode was unbeatable.
Interior.
From the ergonomic point of view, it’s a good or very good change. I wasn’t that bothered with seating position but some were. Now, the dash is visually not designed, and that’s a big problem for me, to look at something I don’t like every time I drive. It bothers me big time.
In person, does it looks and feel better than in photographs? Yes it does. But it’s not resolved at all visually speaking. Its design is not connected with the visual ethos of the car.
I miss a pair of recaro pole position as an option, homologated from Factory.
Exterior.
At the back, I prefer the mk2, they‘ve resolved some issues, and the good news is that everything looks interchangeable with the mk1, for those who want to do a mk1.5. You probably just need to set the exhaust tailpipes apart, but this could be done, changing just a couple of tubes. Milltek I’m looking at you.
At the front…it’s more functional, but I wonder if the extra radiator is coolant or oil. If it’s not an oil cooler, I would be surprised. My coolant temps were always stable even on hard use.
In terms of looks, it’s a big step back. Bad design, mk1 looks resolved, this does not. And that’s why black or grey is the colour to go for the mk2. To hide the mess. A bit like in The m3, m4.
I could go on an on on this topic, but basically in terms of performance it’s a step forward, but in terms of looks and identity is one or two steps back.
Auto.
I’ve been told that it’s not very sporty, and what the car deserves (when tracking the car, or pushing it). It will widen its audience, but the car to buy is the manual, don’t make the mistake to buy the auto if you want the car for its intended use.
Chassi.
The best upgrades and in my opinion, the ones that make me think of deserving a swap. The new front suspension geometry is a game changer for those competing and the extra stiffness does help. I wouldn’t be worried on the suspension changes, they work well.
Money.
If money is not a problem, and can cope with how it looks, get a mk2. No brainer. Having an mk1 with some mods…it’s not going to be sensible to swap…the mk2 is better, but IMO not 15/20k euros better for us Who have the mk1.
Summary.
Don’t test the mk2 because you will want to swap…if you can get past the looks and money is not an issue.
I've noticed people talking about this, and I really hope all the annoying aids and assists can be easily turned off in the MK2. My biggest complaint with the MK1 is how hard it is to turn them off, and you can't even do it permanently unless you install some sketchy harness. The MK2 could either fix this by making it simpler or make it even worse.
Never happen, sadly. These are "safety features" and while regs (currently!) permit them to be disabled, they must default to 'on' at startup.
The only one which could be tweaked is the iMT setting. It is insane that this setting doesn't persist between drives.
I guess just having the option to turn off all assists with one button, like by enabling Track mode, would be a huge improvement.
BMW's M cars have had this feature for years. You can save your preferred settings to an M button, and the car remembers those settings every time you start it. That's how it was on my ‘21 M2C, at least.
Chasis.
Your post says it in a different way but I agree. On the chassi part, where did you test, as in what kind of roads? Usually UK journalist give a reservation for testing the car on local B-roads...
Embarrassed I didn't think of this before, but was more or less in the same position with the 2012 GT86 I had, as an early pre GR era GR enthusiastic, with time oem+ modded, and then the facelift came, better chassiz stiffer body, better interior. And then the GR86, better everything again incl engine. I never regretted having the OG modern 86 and if I still had it wouldn't have considered the newer ones (taking out of account very high mileage/worn etc) as I had made it my own already. And having sold it, happy there is a GR86 now if I ever wanted to return to the concept.
Strangely, that gravel suspension starts to make even more sense now for the future, as upgrading like for like will be much more again :p
Just to clarify, I haven’t driven the mk2 myself but have spoken with people who had, and those people have a lot of experience driving the mk1 both street and race versions. What I say in the post is the info they conveyed to me…
... it's not enough what the new one brings. Same seats, same steering wheel, body, everything the same...
Look, Toyota UK calls it the "All-New GR Yaris" and they are the salesman, ok?
tumblr_ln3r48ju4B1qirvj1o1_500.gifv
They have tuned and tweaked the GR Supra multiple times over the past few years. I feel like the only reason this feels bigger is because there are actual visual changes, and for me personally, the MK2 just looks worse. I really dislike that new front bumper. 🤷‍♂️
The other changes are nice, I actually sort of like the new interior, though I think they could have done better. But it's not enough for me to consider swapping, if it will even be sold here. Maybe I will consider if a MK3 ever comes along.
5b Exhaust
The GR Corolla made more power because of a better flowing exhaust. And when looking at MK2 pics from the rear, I could swear the tips and the piping are just a tad larger.... TBC
5c fake exhaust sound
From vids it's quite obvious the fake exhaust sound is either dialled down or maybe straight up absent. To my liking.
Wow, powerslides on dry tarmac?! With the MK1 @Phil1291 reached a stage where he reported being able to enjoy powerslides, but that came after a power increase of a lot more than 20ish bhp, if I remember correctly, plus many more upgrades in parallel. And even then, I don't think he reported huge, prolonged powerslides; quite the opposite. But then again I cannot do powerslides on dry tarmac with the MK1 fullstop; not with weight transfer, not with any other driving technique. So, maybe it's a matter of skill (or lack of, in my case). Still surprised to read about powerslides implied on dry tarmac in the set-up-for-grip 4WD 2xx bhp GRY.
Chassi.
Good to know you're enthusiastic about the chassis upgrades. Could you please elaborate on what you think are the most significant changes, with any details you may have, if any are available to you at this early stage?
I mean, what changes exactly in the front geometry make you feel these are a game changer for some? In terms of result, are you referring mainly to the ability of the new car to better maintain the alignment settings with the suspension compressed (an issue pointed out by @Phil1291 )?
Also, if you happen to have any details about changes to the rear suspension, please share together with any views you may have on these. I ask as @Phil1291 hinted towards potential major changes there (at 9:02 of his video). Even if there aren't any major changes, it would be useful to know even about minor parts being upgraded, as, for example, expert users have reported about the rear trailing arm bush in the MK1 coming straight from the humble Yaris and that having it upgraded may tackle the GRY's tendency to snap oversteer at times (alongside with improvements to steering, etc), while finding a decent upgrade that will stand the test of time (and salty roads) hasn't been easy.
I appreciate it may simply be too early and difficult to have such details and I'm still grateful for all the valuable and reliable updates you have been providing proactively and consistently. (y)
Exterior.
It's funny but I see this whole car as a mk1.5. The changes are only minor really. It's reminds me of when I had a Golf R and they made it from a 7 to a 7.5. That also had different gearbox from 6 speed DSG to 7 speed and interior and exterior styling updates.
