Lauren
As many will appreciate, the stock audio in the GR Yaris circuit pack is nothing special and whilst it is adequate and has good sound separation, it lacks depth, bass and mid range. In my last car (GT86) I had a £3K install, which was simply astoundingly good. However, when I checked behind the sofa, I couldn't quite find that kind of money. My friends from RRG Macclesfield, Richard and Chris were in a similar situation. What we wanted was something affordable that would make a good improvement without breaking the bank.
To that end Chris had enquired with Tim at Trilogy In Car; http://www.trilogyincar.com/
What Tim came up with was some upgraded Alpine S-565 speakers to replace the originals and also a rather good flat active sub in the Focal ibus 20 that fits very neatly under the passenger seat. Tim can fit this for you for £750.
As you can see from the pictures, it is fairly involved and also includes a remote adjuster knob for the subwoofer so you can vary the amount of bass. I feel that an active subwoofer is key, because you can take the work of the bass away from the door speakers. This installation uses all the stock fittings so nothing is cut. The original front door speakers are sacrificial though as Tim uses the mounting baskets to mount the new speakers. No great loss there.
I've literally just driven home from Stalybridge which is a half hour drive and the difference is astonishing! I do need to run the new speakers in a bit, before they'll give their best and I will update after a week how I'm finding it.
OEM speaker:
Volume control for sub which is stuck to the dash, not drilled:
Subwoofer:
OEM speaker:
Subwoofer:
