Expired WANTED Front GRY Tow Eye Cover
Status
Not open for further replies.
Germy
Devoted member
As per title.
Condition unimportant, stone chips, broken clips ok (ideally one that still fits and is whole though!) as it's for an experiment!
UK shipping required
As per title.
I bought one from Toyo Oz in case I messed up the drillium for the tow eye. About $100 so in UK probably 50p and a handful of gravel.
I'm going to pop in to Toyota and get a price on a new one anyway ๐Ÿ‘ will let you know how much gravel they want ๐Ÿ˜‚
Pretty lousy pic, I can get a better one if this is what you are planning...
It is easy to line up the centre of the hole because the cover has two long straight edges. Screw the eye bolt in, slide the cover along one edge until it meets the bolt and mark centre, slide the other way, mark centre and then guess where the twain shall meet! I started with a 10mm hole, remove the tow eye bolt and you can see how the hole lines up with the tapped hole for the bolt. Adjust as needed and then use a step drill to go out to (I think) 32mm. The rear I just removed the two piece panel because the hole is only 50 or 60mm diameter and close enough. Actually easy if this is what you want the cover for. I ran mine without the cover and it leaves a gaping hole around the tow eye. Enough that it would be the boys in blue interested if they had the car on the side of the road for some reason...
Hi I like your towing eye were did you get that from?
Grant
Status
