Andyoz
Absorbed member
- Feb 7, 2023
- 44
- 31
Att: Northern Ireland Members
GR Yaris Circuit Pack with Pearl White paint, two owners, low miles (7,970) and subtle OEM+ modifications.
Major Service completed in Sept including differential oils.
Interior and exterior immaculate.
Car ceramic coated early in its life and has been always garaged by myself and previous owner.
Underside is also immaculate (see photos). Car was professionally undersealed at 3000 miles with Bilt Hamber Dynax-UC clear coat and Dynax-S50 for cavities. Car has never been on salted roads. Never used as a ‘daily’ and generally only longer runs with proper warm up. Still has protective film on door sill metal protectors.
Full Toyota service history at following intervals so still under the extended 10-year warranty:
- 1st Service: 5 Sept 2023 - 3,057 miles (Minor)
- 2nd Service: 27 Sept 2024 - 3,353 miles (Major)
- 3rd Service: 10 Sept 2025 - 4,925 miles (Minor)
- 4th Service: 9 Sept 2026 - 7,717 miles (Major incl. Differential oil)
The following subtle modifications have been professionally installed for an OEM+ spec car with alignment setup for ‘fast road’. All original parts are being sold with the car:
- Milltek resonated exhaust
- Tein S-tech lowering springs (25mm front/20mm rear)
- String Theory 21.5mm spacers
- Whiteline Anti-Roll Bars
- Whiteline Camber adjustment Bolt kit
- Powerflex Lower Torque Gearbox Mount
- Cusco front strut brace
- Carbon fibre stone guards (to protect paint rear of arches).
Springs were selected for their spring rates which are similar to stock car and provide only subtle lowering. Photos show cars stance with plenty of arch and underside clearance for our roads.
ARB’s allow adjustability and a slightly more ‘rear-end ‘bias. Miltek exhaust is the resonated version providing a moderate increase in volume level. Lower Torque Gearbox Mount provides a more positive gearshift without NVH increase and protects the stock factory rubber mount that is prone to failing.
PS4S tyres all round. Still on original rear tyres dated late 2021 with I estimate over 60% tread. Fronts are dated 2024 and were changed as a pair due to unfixable bolt puncture in one and I estimate over 70% tread (see photos).
Car has never been mapped or tracked by myself or previous owner.
Had first MOT this year and valid until Aug 2027.
All original receipts and paperwork for services and modifications present (including scanned copies).
Private plate GRZ910 is being put on retention and it will be sold with original plate BYZ6404.
NI car from new and previous owner was known to me and also a careful user.
