GR Yaris Evo Corse Wheels @ String Theory
StringTheoryGarage
Devoted member
Vendor
Stratford upon Avon
Hello everyone!
We have taken on Evo Corse wheels as we felt like instead of going for "Rally Replica" Wheels we would just get the actual thing!
We have a couple sets in stock right now, with a bit of money off for marketing purposes so that we can get some photos of them on GRY's for the site.
Here's what we have in stock now -
Left to right
Z.A.R - Black - 18x8 ET28 - £1250
Sanremo Corse - Gold - 18x8 ET35 - £1325
Montecorse - Anthracite - 18x8 ET35 - £1325
Montecorse - White - 18x8 ET45 - £1300
Montecorse - Gold - 18x8 ET45 - £1325
Sanremo - Gold - 18x8 ET35 - (Sold)
All wheels come with centre caps, bolts and metal spigot rings!
Fitting the wheels is free or we can post them out to you (around £45 shipping to mainland UK).
We can supply tires / swap tires at extra cost if needed.
Regarding the sizes and offsets, we only have them in sizes that will fit the stock arches, however bigger sizes can be ordered if needed.
A guide to offsets and widths / Fitment ;
18x8 ET45 - Same as OEM Fitment ( Can use with 21.5mm spacer)
18x8 ET35 - 10mm further out than OEM fitment
18x8 ET28 - Same fitment as if you were using the 21.5mm spacer kit and OEM wheel, just without the spacer.
What do you think? What do you like and what dont you? This is a new wheel brand for us, but we are over the moon with how they look on our car -
Heres some more examples on GRY in different colours -
Montecorse in Anthracite
Z.A.R in Black
SanremoCorse in Anthracite
Get in touch with any questions you might have!
Cheers
Fraser
Some of them look great. Do they come in GR86 fitments? How much do they weigh?
Absolutely! We would need to order wheels as the GR86 is 5x100, where as the GT86 is 5x114.3
GR86 OEM 17" wheels look to be 17x7.5 ET48, so
18x8 ET45 would be 9.3mm further out than the current wheels,
18x8 ET35 would be 19.3mm further out than the current wheels,
18x8 ET28 would be 26.4mm further out than the current wheels.
I image the ET28 wont be possible without issue with the arches, however the others will fit fine.
We would need 2-3 weeks worst caseto get a set, but we can do that if you are keen!
If you happen across the SanRemo or MonteCorso in 17x8, I'd love to know if they fit over the GR Yaris brakes.
Thanks!
Interested as some of those look great! Particulary like the Z.A.R. in Graphite with red text - would look good on my Red GR86 me thinks!
According to Evo's websire they do the exact size without the need for Spigot rings too:
The Sanremo Corse look good too. Do any come in a dark Bronze rather than bright gold?
But a correction if I may as the sizes for GR86 you quote are not correct as they're 18" as standard if that makes any difference at all.
U.K. Standard fit 10 spoke black alloys:
Diameter: 18 Inch
Width: 7.5 inch
Offset: ET48
PCD: 5x100
Centrebore : 56.1mm
Weight: 10.4 kg TBC
Wheel Fasteners: Lug Nuts , thread size M12x1.25
Torque setting: 120 Nm
The gold evo corse look great.
I have the 18x8 motorsport version in gold,....with no center cap,as center caps arent allowed in rallying.
Speedline made them with a slightly deeper dish....(i think they are similar to the ones "sanremo corse" in your pic)...but if yours come with center caps then they arent the same...haha)
Look great!..proper wheel!:cool:(y)
(Just to add....18x8 ET35 even with a 7mm spacer (which would make it et28)...are totally fine and dont rub,even on a -25mm lowered car)(y)
whats in the fitting kit?
The fitting kit is;
4x Center Caps
20x Evo Corse Wheel Nuts (Black or Silver)
4x Anodised Aluminium Spigot Rings
If the wheel is 60.1mm Center Bore then there are no spigot rings, but if it is 75mm then they come with 4x Anodised Aluminium Spigot Rings
We are really into the Evo Corse Z.A.R Wheel at the moment,
We have a set on route for ours, to change up from the SanremoCorse in Gold we currently have fitted.
The Z.A.R fitted are both 18x8 ET28, they are part of the Arcasting Range which means they are lightweight.
Here are two customer cars on Z.A.R to show -
They do them in White, Anthracite, Gold and Black -
What do you think?
Cheers!
Fraser
Very nice! :cool:
Are they around the same weight as OEM Circuit Pack wheels!? :unsure:
Ben remembers them being 1-200grams lighter than the OEM Circuit Pack wheel + Spacer,
When this batch turn up soon, ill get one weighed up to confirm thought!
