Sold GR Yaris Circuit Pack - Highly Modified
  • Thread starter Thread starter Deleted member 4323
  • Start date Start date
Status
Not open for further replies.
D
Deleted member 4323
Guests
Hi and welcome to the sale of my very tastefully modified Toyota GR Yaris Circuit Pack. If you are looking for a standard car then this is not for you so please respect the advert and the info within. I have included as much detail as possible but please contact me if you require any further info. I have invested a lot of time and pride to get this car to this standard and would respect serious enquiries only please.
Thanks.
General Info
Colour - Glacier White
2021 (71). Private plate on at present which is not included. OEM plate - RV71 CXP
First registered on 10/09/21. Balance of the 5yr Toyota warranty until 10/09/26 with the option to extend for a further 5yrs when using Toyota service and parts. Please note any modified parts may affect warranty claims.
Mileage - 9,035. Weekend dry day use only. Never driven in wet conditions or over the Winter months in my ownership. Mileage may rise slightly with weekend dry day use only.
2 Keepers (I am the 2nd). I have owned the car since 02/04/24 (purchased with 6,654 miles) and covered 2,381 miles in my ownership.
Last drive for 2024 was on the 05/10/24 and SORN (8,776 miles) on 02/11/24 until 01/04/25. Car is not used over the Winter months.
Car was taxed for 01/04/25 with 8,776 miles. First drive of 2025 was on the 06/04/25 with 8,776 miles.
V5 Document in my name.
Toyota CAT 1 Alarm & Immobiliser
2 Keys Fobs. Spare is unused.
Tax - £195 per year
First MOT Date - 13/08/24 (8,531 miles with no advisories)
MOT Expiry - 09/09/25
HPI Clear with 2 x Reports.
Full Toyota Service History. History and any repair work available online (My Toyota) and in the service paperwork (Service Book partially stamped as previous Keeper preferred online history. Email available from Inchcape Toyota, Guildford with details of past history).
A4 folder full of receipts for all work including all aftermarket parts.
Original Booklets and also a full selection of printed GR Manuals.
Zero leaks of any kind from the engine and zero internal leaks.
The car is in immaculate condition and has all the std Circuit Pack features which are all in full working order. The car also benefits from the below high value complementary parts spec which have been fitted in my ownership from April 2024 to date. Over £15,000 (with fitting) worth of aftermarket parts fitted.
Never tracked by me or previous Keeper (email proof available from previous Keeper, Mr D Cooper).
Always garaged and covered when not in use.
Always ran on Shell V-Power petrol.
Service History
10/05/22 - 4,169 miles
12/09/22 - 4,735 miles
19/09/23 - 6,222 miles
11/04/24 - 6,936 miles
23/04/24 - 7,289 miles (in for gear change noise/crunch (common issue and nothing found) but also changed the diff and gear box oils).
12/04/25 - 8,823 miles
Millers Oil - EE Performance Fully Synthetic Engine Oil With Nano Tec - 0W20 - API SP - ILSAC GF-6A (far superior quality spec oil over the OEM product).
Service work carried out using all genuine Toyota parts and all history & repair information available online (My Toyota).
Engine & Gear Box
Eventuri Intake Kit in Matt Carbon
MST Turbo Inlet Elbow (black)
Airtec Gear Box Mount (yellow)
HEL Braided Clutch Line (red)
GR Sport Oil Cap (red)
(Fitted at 8,260 miles)
CAE Shifter (black) with Red Anodised Aluminium Gear Knob (CAE fitted at 8,856 miles)
ECUtek remap by Jamie Lumley at Evotune (highly reputable tuner in the North East) with switchable dual maps (Map 1 - low boost & Map 2 - high boost) from the cruise control cancel button. Running 340bhp and 340lbs ft. (Graph available). Very healthy and reliable map that makes a huge difference to the way the car responds and drives. Remapped to run on Shell V-Power petrol.
Remapped at 8,260, 8,357 & 8,415 miles. 3 x maps to carry out initial map (dyno mapped) and map tweaks (road mapped) due to flat spot in 5th & 6th gear at 6K revs.
Exhaust
Milltek Non-resonated Catback Exhaust with Carbon Tips (sounds epic)
Milltek Non-resonated OPF Delete Pipe
Cat Pipe (OEM)
(Fitted at 6,835 miles)
Suspension
Ohlins R&T Coilover Kit (lowered approx. 50mm) with Coilover & Spring Neoprene Covers
DNA Adjustable Top Mounts
Blitz Front Strut Brace
Whiteline Front 24mm ARB
Whiteline Rear 24mm ARB
Whiteline Front Droplinks
Whiteline Rear Droplinks
Whiteline Front Camper Bolts
4 Wheel Alignment set up for fast road use.
Brakes
Std Front & Rear Brake Set-up with OEM discs & pads (8mm on pads)
Front HEL Braided Brake Lines (red)
Rear HEL Braided Brake Lines (red)
Wheels & Tyres
OZ Ultraleggera 18”x8”, ET35 in Bronze
Michelin PS5 Tyres (as new)
Genuine Toyota TPMS Sensors
String Theory 21mm Spacer Kit
RC Developments Wheel Nuts
GR Dust Caps (red)
(Fitted at 8,203 miles)
Interior
Alcantara OEM Steering Wheel with Red Marker and Stitching (by Snappy)
Alcantara Wrapped Airbag Housing
Alcantara Wrapped Steering Wheel GR Base
Alcantara Wrapped Steering Column Housing
Alcantara Custom Made CAE Surround
Alcantara Wrapped Window Switch Covers
Alcantara Wrapped Dash Inserts
Alcantara Wrapped USB Port
Alcantara Wrapped Entertainment System Surround
Alcantara Wrapped Glovebox
Alcantara Wrapped Gear Surround
Alcantara Wrapped Seat Inserts
Alcantara Wrapped Arm Rest
Carbon Wrapped Dash Side Panels
Carbon Wrapped Interior Light Surround
Stainless Steel GR Gear Change Plaque
GR Dash Infotainment (OBDII plug in) fitted on 07/05/25. Monitors all temps and systems of the car and retains the Apple CarPlay (wireless). This is an awesome bit of kit and looks OEM when in use.
Rear View Mirror Riser
Carbon Effect GR Door Latch Covers
XRS Performance GR Stainless Steel Footrest
Gloss Black Toyota Steering Wheel Overlay (by 21 OVERLAYS)
GR Mat Set (OEM)
Rear Boot Mat
Exterior
Full bottom half PPF inc. wings, lights, bumpers and bonnet (OEM)
Carbon Fibre Roof and Carbon Wrapped (OEM)
Rear Window Tints (OEM)
Carbon Wrapped Bonnet
TRD Wind Deflectors
TRD Side Stripe Kit
TY-Motorsport Carbon Spoiler (available to fit)
TRC Front Splitter with TGR Decal (available to fit)
HT-Autos Rear Bumper Vents (available to fit)
HT Autos Front Bumper Canards (available to fit)
Automotive Passion Carbon Front & Rear Mudguards
Automotive Passion Black Rear Yaris Badge
Tinted Front & Rear Toyota Badges (no impact on front radar)
Custom made front number plate holder
Lights
Tinted Rear Brake Light
Tinted Rear Foglight
“That Foglight Guy” Yellow Spotlight Covers (also have spare blue covers)
Underside
The underside of the car is in fantastic condition with zero rust on any of the components. Small signs of minimal surface rust on some of the OEM nuts and bolts. Lanoguard Protection on all underside parts which was applied on the 20/04/24.
Additional Parts Included
Also included in the sale are all of the OEM parts including.
Air Intake System & Filter
Full Exhaust System
All Suspension parts
Gear Stick
Steering Wheel (OEM for the car)
BBS 18” Wheels (mint condition) with genuine Toyota TPMS Sensors and Michelin PS4 tyres (all 6mm tread).
ISSHO Cuddly Toy
Wicker Key Basket
Reason for Sale
Only selling as I am looking to change to an Escort MK1, MK2, RS2000, Cosworth or a Classic Ford of some type.
Photos
I can only upload a maximum of 10 images. I have a good selection of photos which show the car in various stages of build to give you an idea of what the car looks like in std & modified condition so please contact me if you require more.
Areas for Improvement
As stated the car is in immaculate condition both inside and outside. The only areas I see that require improvement are 1 x stone chip on the passenger wing & a slight mark on the bonnet which are both in the PPF in the PPF and have been pictured.
Price
Based on the spec, condition, service history, mileage and all OEM parts etc. I am looking for £34,995 firm.
Test Drive, Contact Info & Location
Test drives will be by me only unless you van provide proof of a full license & insurance and take full responsibility of any damage etc. Car will only be available to view on a dry day.
Please contact me via PM or [email protected] if you have any further questions.
Car is located in Durham, North East.
Cheers,
Phil
Hello @phil555,
Marketplace thread auto-closed. Re-list if still available and remember to update the thread as Sold when it's sold.
Status
