- Dec 16, 2021
- 223
- 352
- 63
I thought I’d ask this question as I think I see the reason why, but wanted to throw some more thought into it
The car limits BHP output on warm up, like other performance cars, however these appear to be limited by rpm and not load. I understand this faster moving valve train, pistons etc would need thinner oil.
Why does the GR limit on Load, surely 7,000 rpm at low load or high load is the same frictional effect on the valve train?
Now here’s my thought. Is it load restricted to limit differential of the heat within the block? Higher mechanical BHP/kW output will produce higher heat output. Are Toyota limiting heat output to minimise heat differenatail in the engine?
I’m thinking it’s an open deck, small displacement engine so perhaps it’s “prone” to higher expansion rates ? Or could it be an emissions thing?
Thoughts please
Or it could be something completely different , just wanted to get other peoples take
Thoughts please
