Got this steering spacer installed today: https://www.spacershop.com/en/product/steering-wheel-spacer-toyota-gt86-facelift/
The instructions will come with it and this is a video:
However thought I'd share a few things I learned from the install:
Anything to add @Grblue86 ?
- Be gentle with everything and take your time. Follow the written instructions and watch a few videos before starting. If you are close or you hit something with a tool, stop and tape it up, takes 2 seconds and saves permanently marking something.
- Grab all the tools listed to save back and forth to tool box.
- There is 3 springs to press to remove the airbag (only makes sense when you see it), 2 near the top and one on the bottom left, look for something like coat hanger wire.
- Horn cable seems hard to remove but has tiny tab to press and will pop right off.
- The white connector for buttons has a tab which you may need to press in to connect.
- Reconnecting the airbag wire is tricky, the video covers this well.
- When you've installed the extender, the wheel won't fully engage with splines until the nut is tightened, so don't be surprised if it feels loose before this point.
