GR Yaris Steering system weird sound
moro
Fascinated Member
Jan 3, 2024
33
23
8
When steering at low speeds or while stationary, the car is now making this weird sound. Of the things I have changed, the ones relevant that come to mind are: suspension (KW v3 coilovers), top mounts DNA (adjust camber and caster). This is with the original wheels+tires. No spacers.
What should I check? any ideas?
Here is the sound in a 10 sec video:
either you have a Chewbakka hidden in your dashboard or your power steering might be failing. have you consulted Toyota for the issue?
No, was hoping to be something I could see or fix myself first..
Sounds a bit like tyres rubbing on shiny concrete surface. My old car did something similar. Does it do it outside that underground carpark?
I know that sound.. but this is rough concrete, it does the same on tarmac and other surfaces too :S
