GR Yaris Scara73 brake discs?
This will be my next upgrade once the discs need be replaced.
6kg mas saved will for sure be beneficial to handling. Just hope that they're not "cigarette paper thin" and wear out before the pads !
Reactions: Sekred
I feel like I might be missing something.
We all know that reducing unsprung mass and rotational inertia is great for improving handling and acceleration. But at the same time, you also want your brake disks to have enough mass to act as a heat buffer to avoid brake fade during heavy braking. Sure, lighter brake disks can absorb the same heat than heavier ones if cooled more efficiently. But in that case they will experience higher thermal stress due to wider temperature fluctuations.
Given how much effort Toyota put into weight management on the GR Yaris, I have no doubt they carefully balanced the brake disk mass to optimize braking performance/handling/acceleration.
Some aftermarket manufacturers offer lighter brake disks emphasizing better handling. Are these really so advanced that they shed heat faster and use materials strong enough to handle the added thermal stress? It could be true, but I feel like if that were the case, manufacturers would highlight it more boldly in their marketing.
Maybe the real answer is more practical, perhaps the people buying lighter disks know exactly how they'll be using them. Maybe they don’t push their cars hard on track, or they drive on circuits that aren’t particularly brake intensive. Or maybe they’ve added extra cooling to compensate for the reduced mass.
In my mind, lighter disks aren’t clearly beneficial unless you’ve carefully weighed your priorities.
Am I overlooking something here?
Cost is also a factor - eg the vents in the OEM discs are not "handed". I imagine the weight saving comes from bigger/more vents in the disc, and you're balancing better cooling from that with the reduced thermal mass.
"will save you 5.6kgs in un-sprung weight on the front axle" ... "Eliminates the poor cooling issues of the standard setup, which is proving to be an issue on these cars with track use" ... "more resistant to warping due to special alloys within the Iron disc"
I have the alcon discs, and they get a regular kicking on track with no issues. I have extra brake cooling, but I had that with the OEM discs as well. They are similar cost to OEM, but 40% cheaper for the next few sets as you reuse the bells.
Personally I would only get discs from the bigger boys - AP/alcon/brembo. I think these mostly don't specify a minimum width, but just say to inspect and replace when the disc starts cracking.
Reactions: Spirited and tonic
Could be. Driving so light sessions on track with extra cooling so cannot think it would be any issue espec from reputable manufacturer such as Alcon or Endless.
Yes Toyota has done their engineering but imho its not 100%. And factory discs have cracked aswell even they’re 10kg so.. im sure there’s room for improvement even its a Toyota.
