GR Yaris (Gen 2) Power to a Dash Cam using a OBD-II Adapter
Torque
Fascinated Member
Kent, UK
I had a dashcam hard wired, there is a fusebox behind the glovebox, I used a fuse under a removeable small cuver ignition switched. i would steer clear of an OBD power source as it could cause issues later on.
Thanks for that...... I've done more research and as a result I'm coming to the same conclusion that hard wired to the fuse box is less likely to cause issues.
The following video raises some interesting points:
I have one on my van. Garmin dashcam and garmin connector. I have had little problem with but it will drain battery, though that maybe limited to the van as I think the drain is quite high. Defo no warning lights that I would worry about.
Here’s an update on my quest to power a Dash Cam, rather than hard wiring to the fuse box or using an OBD-II adapter, I opted for another solution, that might be of interest to others.
It’s an adapter that utilizes the power behind the inner rearview mirror.
A Mangoal Dashcam Power Adapter for Toyota/Lexus 16 Pin (Model D):
https://www.mangoaltech.com/product...-lane-assist-port-hidden-powers-gps-radar-etc
Although not specifically listed as being compatible with a GR Yaris I can confirm that a Gen2 GR has the required 16-pin connector (and Adaptive Cruise Control/Lane Assist).
Note this adapter only provides power when the engine is running.
This adapter can be ordered direct from Mangoal or as I did from Amazon.
It’s a very neat and simple solution(y)
Will this also work with the Gen 1 Circuit Pack mirror?
