That’s phase 2 for the extra 30bhp!Have you got any drinks holders, stripes on the bodywork, or a gr-zoo.com sticker?
Thats the key to add more than 1,6 bar boost and keep torque up at 5000+ rpm, so I guess if you can run 1,7 or 1,8 you get close to 400 hpKelford valve springs
Syvecs ECU
In an ideal world I'd do something about the exhaust at the same time, but £ for £ I think the valve springs will do more than a HJS downpipes, hence going that route initially. Might test it without the GPF just to see the impact, but don't want to go all-out track car.Thats the key to add more than 1,6 bar boost and keep torque up at 5000+ rpm, so I guess if you can run 1,7 or 1,8 you get close to 400 hp
But it will be hard with stock cat / exhaust to run that high boost
Stock turbo I doubt can maintain that boost above 5,000rpm Although I could be wrong. I would be surprised if I saw any car produce more than 360 on a stock turbo.Thats the key to add more than 1,6 bar boost and keep torque up at 5000+ rpm, so I guess if you can run 1,7 or 1,8 you get close to 400 hp
MPS did 400hp on full turbo back, Wagner IC and 102ron + ethanol (30%?). Without E 380hp.I would be surprised if I saw any car produce more than 360 on a stock turbo.
All tuners using standalone ECUs so far have reported boost has to be reduced above 5/6k rpm to avoid float (down to ~1.3 bar) So if this can be avoided and say 1.8 bar be maintained then there should be a power gain at the top end. Question then is can the stock turbo flow that much or would it run out of puff anyway.Springs are surely only going to increase power (prevent loss of, really) if you’re already suffering float at high rpm?
