Was not the most staright forward install but we managed to get it working by
using
- xbb output 1 for High beams and
- xbb output 2 for IGNITION.
Light switches on when putting lights into manual and switching first time for the high beams.
Put to low beams it goes into low light support mode.
Switching back to auto lights led bar seems to stay on (even though it should not, as xbb states it works only in manual lights mode).
didin't test what happens if in auto mode put into high beams but will test it later.
AND remember to pair the power relay also from the app. it took a a while to understand that also power relay needs to be paired with the phone, not only the obd. getting there...
using
