GR86 Handy bits n bobs
midlife_sportscar
Manchester
Just some things I've found that may or may not be obvious/useful:
When using Android Auto, press and hold the voice button to launch Google Assistant directly - much easier than poking the microphone icon on the screen.
When the ignition is off you can push the trip button to cycle through the mileage displays and this also displays the fuel level.
Push and hold the Source button to mute the audio, tap it again to unmute - oddly, this isn't the same mute function as the power/volume knob so if you mute from the volume knob, pressing Source will change the audio source rather than unmute.
The clock was set to manual and didn't adjust for DST, setting it to 'sync with phone' fixes that (to be fair this is in the manual).
You can flip from MPH to KPH - super handy when popping to Europe
There is a boot release button on the dash
