GR86 GR86 Maintenance
ZN8
Administrator
Staff member
Kent
Hi All,
I've shortlisted some information from the owners manual in regards to maintenance FAQs associated with getting a new car, link to a pdf version of the manual from AndyRC;
GR86 U.K Owners Manual
Opening the Bonnet
p302
Jacking point Locations
Axle: The front jacking point will likely need an ultra slim long reach jack, the rear diff is easier, as it's not so deep under the car and the clearance is higher p303-304
Side: p321
Wheel Nut torque
89lb/ft (120nm) p387
Oil
Grade (0w-20) + Quantity p382
Level check p306
Diff oil
Grade (75W-85) + Quantity p384
Coolant
Level check p307
Grade p308
Brake Fluid
Level check p309
Grade (DOT3) p309
Tyre Specs + Pressure
(35psi all corners) p387
Light bulb types
p387
Fuel
Capacity (50L) p381
Grade + information (98RON recommended, 95RON can be used without detrimental effect) p381, p388
Opening the filler cap (fuel tank cap fits into the filler door) p169
Opening the filler cap from inside the car p369
Tyre Pressure + TPMS (Tyre Pressure Monitoring System)
p354 + p315
Key Fob
Operation p102-103
Battery Replacement (CR2032 Lithium coin battery) p329
Battery lifespan 1-2 years, a message will display on the dash when its low.
Keyless Entry
Operation p105
Battery saving mode p112
Pollen/Cabin Filter Replacement
p327
Fuse Box Locations
p321
I can recommend Millers 0w20 oil. It made a good and nicer noticeable difference as is more miles after 1k run-in . I early changed at 1200 miles.
