GR Yaris Front door speaker upgrade
Chris Pulford
Dec 16, 2021
32
36
18
Macclesfield Cheshire
Front speaker upgrade on the Yaris GR, the oem speaker cones were cut out of the frames and discarded, the upgraded speakers were mounted on the oem frames, the terminals of the upgraded speakers were soldered into the oem plug to keep it looking all original as possible, a small amount of dynamat was fitted to the outer door skin and inner to help with resonance and vibration. All fitted by Trilogy in car audio in Stalybridge.
Under seat sub next to be fitted 🤦🏼‍♂️🤣
I can’t fault the alpine speakers at all, the sound clarity is really good, the dynamat also has definitely helped, the volume on the media unit can be turned up to maximum and there was no distortion, I felt I was still missing some bass so I’ve also installed a focal ibus 20 which has gone under the passenger seat and that’s transformed the system to a different level
Reactions: marcusfordus
What is a very good direct replacement speaker upgrade for front and rear ?? for more bass/overall quality...BUT im not into fitting amps and stuff.
Just a speaker upgrade
