B Beefstah New member Sep 10, 2022 1 0 1 Sep 10, 2022 #1 I've picked up a puncture, and may need to replace the tyre. Do I need to/should I replace the other tyre on the same axle? Do I actually need to replace all 4? The set on there has done 12k, and has 5.5mm of tread left
GRgrampa Totally Hooked Dec 18, 2021 458 513 93 S. Wales Sep 10, 2022 #2 I would replace the pair on the same axle and keep the good one as a spare.
Araf Obsessed member Dec 18, 2021 348 426 63 22 miles from Calais Sep 10, 2022 #3 8mm is the starting point. My rule of thumb is to replace a pair if over half worn or if I cant get a matching brand and series of tyre. Reactions: Deleted member 534 and Damo996r
