GR Yaris CODE for radio.
GR- FOUR
Mar 20, 2024
41
66
18
Just a quick question, if you remove the battery or the full screen & radio, do you require a 4 digit code on start up when power is applied ?
I've looked in the glove box and user manual and can't find the label if there is one.
Or is it a call to the dealer with my VIN number.?
Regards Russ....
No code required even if you change the headunit.
Thanks for quick reply , I'm looking at fitting the IDoing plug and play unit, watching the install video done by Marc and cars in Australia he mentioned a code at start up, it may be something they supply, I have emailed them to ask as I wasn't sure 👍
Just to add to this, I've contacted the lad who did the installation video for iDoing android unit for the GR Yaris, the code is supplied is for the CAN BUS by them at start up.
Regards Russ....🙏
