Berkshire
Grblue86
487
612
93
Reading
Just thought to make the first thread for Berkshire owners although in hindsight given the small size of Berkshire and how close it is to other counties (Oxfordshire, Hampshire, Surrey) may be it is best to have a "South" thread instead. Let's see.
Reading here
Reactions: grisszoo86
Reading here
Bracknell here
Gris Zoo (as mine is called) is hibernating for winter. Given how cold it is I feel I should be doing the same!
Despite the number of sales Bracknell Toyota made I have only seen 4 in the area since I got mine in December 2022.
Yes Iam on the Oxfordshire/Berkshire boarder, collected my black 86 from reading in September.
Nearly at the 1000 miles mark . I have seen a black one in Henley as well.
Marlow/Maidenhead here.. number of GR Owners seen about he Bucks/Berks/Oxfordshire area. Saw x2 in Henley on Thames last Sunday.
S s
Reactions: gazYar
S s
There's a blue GR86 parked around Marlow boat club not too far from Chris Evans home...
Bracknell here
Another Bracknell-ite here. I probably saw your car when it was in Toyotas Compound behind the Coppid Beech. I live across the way and walk my dog down past there pretty much daily!
Keen for meets in sunnier and warmer times.
Looking for a good alignment garage, with a hunter machine ideally. Anyone has a recommendation?
No recommendation, unfortunately; just a few thoughts.
I believe https://alignmycar.co.uk/search/ shows you some of the Hunter machines in any area you search for. It may be that it doesn't show you those without an active subscription, though.
Based on my understanding, the equipment doesn't matter much when it comes to the quality of alignment. It's more about the person carrying it out.
I very recently had alignment done (on a non-Toyota car) at a well recommended and busy garage with the latest Hunter equipment. They handed over the car to me with settings which were not the ones I had asked for and a few other issues, mainly that they forgot to tighten the camber and caster bolts on one of the four corners!
I would look for recommendations here and elsewhere and then make a few phone calls asking places that do 4-wheel alignment to talk me through the process. If, for example, it didn't include allowing the suspension to settle before finalising settings and doing a test drive, I would look elsewhere.
If not too far from you, worth giving a call to places like:
Reactions: Grblue86
Although I'm based in Enfield North London I run two other car clubs in the South and a regular start point for our drives is Beaconsfield Services.
Will be pleased to hook up with other GR owners 👍
Cheers SBC
WN73GBO
Silver GR86
Reactions: doogle83 and JR286
